Example Code
Programmatically Set a Sub Panel to Open in the Same Position in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example show how to programmatically set the origin point of subVI to a specific place in a Sub Panel
Description
This example show how to programmatically reset the origin of a called subVI, so that it loads in the same place in a Subpane every timeregardless of the window size and position when the subVI was saved. Note, the main Front panel window will default to being the "zeroth" Pane in the panes[] array (at the index array), but you can manually rearrange the panes, but by default this will work.
In this VI we reset the origin of the subVI to 0,0 so it will load in the origin at the top left corner of the sub panel. When you place controls and indicators on your subVI plan for the origin to be in the top left corner.
Requirements
LabVIEW Full Development System 2012 or compatible
  1. Enter the SubVI path to be loaded in the Sub Panel
  2. Enter the desired Origin Position in the control
  3. Run the VI
  Before and after running the VI
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Comments
Todd S.
NI Employee (retired)
on
well done sir!
Todd S.
LabVIEW Community Manager
joshuatree
Member
Member
on
can u post an earlier version Please...  8.0 would allow a greater majority to open it.
nvm
EricEvola
Member
Member
on
I had this exact issue and this post saved me some sweet time.
Thank you for the contribution. Nice work.
