Example Code
Programmatically Set Camera Attribute using Vision Development Module in LabVIEW
Products and Environment
    Software
  • LabVIEW
    Driver
  • NI Vision Acquisition Software
Code and Documents
Overview
This VI demonstrates how to set a camera attribute using NI Vision Development Module.
Description
In order to use the IMAQdx property node to programmatically change an attribute, you need to know the full name of the attribute.
This example populates a list of all the available attributes for your IMAQdx camera and set an attribute.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
  • If running in a Real-Time context, you will need the LabVIEW Real-Time Module 2012 (or compatible)
 Hardware
  • Camera
  1. Download and open the attached ZIP-file
  2. Open the VI and follow the instructions inside
Set Camera Attribute LV2012 NIVerified.vi - Front Panel.pngSet Camera Attribute LV2012 NIVerified.vi - Front Panel.png
Set Camera Attribute LV2012 NIVerified.vi - Block Diagram.pngSet Camera Attribute LV2012 NIVerified.vi - Block Diagram.png
 **The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Hope this helps.
-Ben
WaterlooLabs
Comments
Ando'o
Member
Member
on
And how can I set the "Command" type attribute or send command? There are different types of attributes for setting (String, bool, U32, U64), but there isn't Command type.
