Example Code
Programmatically Selecting Multiple Y-Axis with Property Nodes Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code shows how to programmatically select which plot corresponds to which Y-Axis.
Description
This code plots random values between 0-1 on one plot and random values between 0-10 on another plot on the same XY-Graph. It uses two Y-scales and property nodes determine which plot corresponds to which scale.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the VI.
  2. Run the VI
  3. Play with the scale bar and observe how the scale changes
VI Block Diagram
Comments
Bill_in_Detroit
Member
Member
on
A simple example demonstrating the use of some of the many properties of graph objects.  This example will save you time reading and jumping through multiple interconnected "help" links when all you want to know is how are these properties used?
GCentral
