Overview
This example allows you to choose the URL of multiple tags programmatically and read them simultaneously. This allows you to read tags and not have to know the URL of each tag beforehand.
Description
DataSocket Select URL.VI displays a dialog box for the user to select a data source and returns the URL to that data. Then open the connection to each tag with a 10s timeout. This example will continuously read the tags until user specifies a stop. Close the connection to each tag individually
Requirements
- LabVIEW 2012 (or compatible)
- Choose number of tags.
- Run the VI.
- Choose server.
- Get the tag URLS and Data.
Front Panel
VI Snippet
