Example Code
Programmatically Save Data with Date and Time as the Filename Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates a method for manipulating the Date/Time string for use as a filename.
Description
The Date/Time string inherently contains characters that are invalid for file path building. By searching the string for invalid characters, and replacing each character with an accepted value, such as an '_', users may save their data sets with files names corresponding to the date and time of the trial.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Run VI.
2. Observe that you logged your data at the address of your VI as "File Name" indicator value.
Patrick Corcoran
Application Engineering Specialist | Control
Comments
koman
Member
Member
on
very useful VI to store data periodically.
