Overview
To Restore the Default Value of the Called VI
Description:
In order to save a VI's current values as default, the VI must be in edit mode. In order to do this we utilize a VI reference and call the Make Current Values Default method. An important item to note is that we set the Wait Until Done input to the Run VI method to True. This ensure that we save the final values, after the VI has completed running, as the default values.
Instructions:
To implement this example:
- Define the directory of the subVI path
- Run the VI to restore the default value of the VI
To execute this example:
- Install the required software.
- Open the VI and refer the Implement Steps
Requirements
Software
LabVIEW 2012 or compatible
Hardware
Senior Systems Engineer
