Overview
This VI demonstrates how to route one or all the PXI Trigger Lines (0..7) simultaneously from the source to destination bus
Description
Here is a brief description of the example:
Using the NI VISA driver, it is possible to programmatically route the trigger lines in a multi-segment PXI chassis using LabVIEW, LabWindows CVI, or another ANSI C development environment. The following example demonstrates how to route one or all the PXI Trigger Lines (0..7) simultaneously from the source to destination bus.
Requirements
- LabVIEW 2012 (or compatible)
- NI-VISA
- NI-PXI Devices
- Initialize values.
- Update the user interface to reflect the state of the VI.
- Respond to user events: Open Session, Route, Route All, Unroute All, Close Session, Stop button presses.
- Check for errors or a Stop button press event.
- Handle errors.
VI Snippet
Mikhail
RF Toolkits, Product Support Engineer
