Example Code
Programmatically Register Events with DSC Module
Code and Documents
This example demonstrates how to programmatically register events between multiple VIs.  Main.vi generates a user event whenever the value of Input String changes.  When the Input String fires, a dialog box pops up notifying the user that an event has been generated.  Once the value changes the DSC module VIs (Enable Value Change Notifications.vi and Request Value Change Notifications.vi) registers for an event in the Read Main.vi.  Once the event has been fired a second dialog boxes will be displayed that lets the user know the event in the Read Main.vi has occurred.
In addition, Main.vi incorporates VI Server to programmatically launch and close the Read Main.vi.  Once Main.vi is called it will launch Read Main.vi.  To stop the program press the Stop button in the Main.vi.
Main.vi Block Diagram
Additional Notes
You will need the DSC Module installed for this example to work.
A_Ryan
AES
Contributors
