Example Code
Programmatically Read All Shared Variables on Network
Code and Documents
Overview
This example VI shows a method to detect and read all the shared variables on every target of the local network.
Description
This VI uses property nodes for the PSP Shared Variable Engine to programmatically detect and read all the shared variables on every target on the local network.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Unzip the attached folder to your computer
  2. Open the VI "Programmatically Read all Shared Variables 2012 NIVerified.vi"
  3. Run the program
VI Snippet
Kevin Fort
Principal Software Engineer
NI
Comments
Himanshu_Goyal
Active Participant
Active Participant
on
Good Job Kevin
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
Himanshu_Goyal
Active Participant
Active Participant
on
Good Job Kevin
Thanks and Regards
