Overview
These two Vis demonstrate how to use the Value (Signaling) Property in LabVIEW to interact with a main VI from a sub VI's front panel.
Description
LabVIEW allows event structures to be activated programmatically by using the Value (Signaling) Property.
If a sub VI's controls need to run code found in the event structure case of another VI's front panel object, the sub VI can alter the property by using control refnums passed from the main VI.
These two programs show a simple example of using event structures and control refnums to generate a random number when a button is pressed on either front panel.
Please see the two documents below for explanations behind the property and mechanical actions of the controls necessary for the implementation of this code.
Requirements
VI Block Diagram
References
LabVIEW Help: Controlling Front Panel Objects Programmatically from a SubVI
LabVIEW Help: Changing the Mechanical Action of a Boolean Object
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
Can you convert your files in Lv11 ? As I am not able to use your example
