Overview
This VI uses VI Server to add a subVI to a subpanel and then to abort and run the subVI on demand.
Description
One use case for this VI may be (as in this example) if your subVI contains an Event Structure. When an Event Structure is loaded, it registers for each event, and will not unregister for those events until the VI finishes execution. This method would allow you to use an Event Structure for a portion of your program, and then to discontinue use for a second portion.
Requirements
VI Snippet
