Overview
The example to save and load front panel control values to/from a .ini file.
Description
There are a number of ways to save a set of control values to load at a later date. Here are two VIs which allow you to save and load front panel control values to/from a .ini file. The example automatically populates an xml file with all current control values to the VI's front panel.
Requirements
Front Panel
Many thanks, this works very well! Even on array of clusters containing arrays of clusters!!!!
Really nice, even with hideously complex controls, but not if there are controls with multi-line labels. Very many thanks.
