Example Code
Programmatically Load Custom Run-Time Menu Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI shows the way of changing Run Time Menu of VI programmatically.
Description
There may be a situation where you need to programmatically change the Run-Time menu for your VI. For example, if you have a large VI that incorporates a few different tests, during the execution of a given test, you need to have a limited run-time menu. However, during other parts of the program, you need to have a completely different, less restrictive, Run-Time menu.
Requirements
Software:
  • LabVIEW 2012 (or compatible)
1. Extract the 7z file to any folder.
2. Run the VI.
3. Flip the switch between "Menu #1" and "Menu #2".
4. Notice that the Run-Time menus change depending on the positions of the boolean switch.
Hope this helps.
-Ben
WaterlooLabs
Comments
Phil_
Member
Member
on
Useful Stuff!
Thanks.
YuChuanHuang
Member
Member
on
Thanks for saving  a lot time!
Well Done!
JastrebokELI
Member
Member
on
Please note that you can also use an RTM of your choice for controls. It needs a hack though.
1) Generate the desired swappable menu as if it was your VI menu and save it using Save->Run-Time Menu invoke node on This VI. (e.g.: MyMenu.rtm)
2) Link this RTM to your control or indicator using Advanced->Run-Time Shortcut Menu->Edit.
3) Use Save->Run Time Menu to save different menus under the same name (MyMenu.rtm). This reliably updates RTM of the control/indicator without the need top generate the menu every single time!
