Example Code
Programmatically Identify Control Class Instances
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI will search itself for all instances of a desired control class.
Description
On the Control Identified indicator we will see which is the control that we are adding on the array of controls. All the controls in the array will blink for three seconds and then it will start again until the VI is stopped manually.
This is helpful for identifying controls that need to be edited or turned into type defs. Typically this is used for inherited code.
Requirements
LabVIEW Base Development System (or compatible)
1. Run the VI.
2. See the controls blinking.
3. When desired, press the Stop control to finish the execution.
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
