Example Code
Programmatically Hiding Controls and Indicators
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demonstrates programmatically controlling the visibility of a given control or indicator on the front panel.
Description
A control or indicator can be made visible or invisible by setting its Visible property. Using an event structure to detect when a button is pressed, we can change the visibility of a control or indicator with a property node. This concept can be used in more complex applications.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI
  2. Toggle the Boolean control to change the visibility of the indicator or control (in this example, a Waveform Chart and a boolean are used)
Front Panel
Block Diagram
Charley Dahan
Global Account Manager
Comments
Todd S.
NI Employee (retired)
on
Great stuff, thanks for posting!
Todd S.
LabVIEW Community Manager
