Example Code
Programmatically Get the Current Values of Controls in a Cluster using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
 Overview
Use this VI to read cluster controls values using their reference.
Description
This VI Use this VI to read cluster controls values using their reference. It keeps controls references and then using an autoindex for loop extract all values using a property node. Values are extracted as variant so this example use a case structure to convert any data in the right format.
Requirements
  • LabVIEW 2012 (or compatible)
1. Insert values in the controls
2. Run VI
3. The controls values are shown in a string array
VI Block Diagram
Cluster Control Current Values LV2012 NI verified.pngCluster Control Current Values LV2012 NI verified.png
Mike S
NI AE
Comments
ahnungslos
Member
Member
on
Thanks a lot, that was exactly what I was looking for!
