Example Code
Programmatically Generate Custom Error Codes/Messages
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This demonstrates using the General Error Handler VI to report your own custom errors.
Description
This examples shows how to use the general error handler to programmatically generate custom error messages. In the course of an application it may be necessary to generate an error even though nothing has caused LabVIEW to generate an error. For example, if you are performing a file I/O task and LabVIEW generates error code 4, an error has occurred where the "End of file encountered." However, if you want to report an error even though nothing has gone wrong as far as LabVIEW is concerned, using the general error handler allows you to generate custom error codes.
An example of a situation where this might apply:
Your program is used to run a motor. When motors run, they generate heat; so in your program you are also monitoring this temperature. In the rare situation where your motor overheats, you want to generate an error, turn off the motor, and end your program. So, even though the temperature of your motor being too hot would not cause LabVIEW to report an error, you need LabVIEW to report that the motor has overheated and close down in a controlled fashion.
Requirements
LabVIEW 2012 (or compatible)
1. Download and Open "Generate Custom Errors_LV2012_NI Verified.vi"
2. Run the VI
3. Trip error 5003 or 5004 with one of the switches.
4. Notice how LabVIEW reports the error as if it was built-in
Block Diagram
Hope this helps.
-Ben
WaterlooLabs
