Overview
Coding that exemplifies how to create and modify cursors.
Description
This VI is simple, but can be easily expanded. it allows you to take data and find the peak values of the data, and then place a cursor on the graph where the peak value is located. We can also modify the color of the cursor, if we would like to display the value, and the amount of cursors desired.
Requirements
LabVIEW 2012 (or compatible)
1. Run the VI
2. Press the Generate Data button to generate a waveform with random data
3. Select the amount of cursors, if the values being displayed is desired and the color of them.
4. Use the Stop button to finish execution.
please add 8.x version VI
done
