Overview
This VI will allow you to either turn on or off debugging for all of the VIs in an entire directory.
Description
Select the path of the vi which to be enable or disable. Select the path of the vi which to be enable or disable. The same method can be used to set other VI properties as well.
Requirements
VI Snippet
