Example Code
Programmatically Edit Items in Combo Box
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This demonstrates a combo box editor that can be used in a running program.
Description
This example VI allows the user to programmatically edit the list of items within a combo box.  We utilize the Strings[] property of the Combo Box to programmatically change the items within the Combo Box.
Requirements
LabVIEW 2012 (or compatible)
1) Open the project and Run the VI "Menu List - Top Level"
2) Click the drop-down to observe the current list of items in the combo box
3) Click on the Edit List button
4) Observe the current list of items contained within the array of strings
5) Add/remove items at will, then press the OK button
6) In the main VI, notice that the list of items within the combo box has been updated
This VI must run in the LabVIEW Editor to use the Save Instrument method as it is not supported in executables. This could easily, and probably more appropriately, be accomplished by saving these strings to a configuration file instead of persisting them as an actual edit to the source code.
Block Diagram
Front Panel
Rod T.
Comments
markfranklin
Member
Member
on
The invoke node notes say that it is not supported by run-time engine.
So is this a solution for compiled applications that do need to run on a machine with a run-time engine rather than LV software??????
RT4CY
Active Participant
Active Participant
on
Yes, the Save.Instrument method is only supported in the development environment.  Thus, this VI cannot simply be built into an EXE and ported to a machine with only the RTE.  There are a couple alternatives.
1.  Use an XControl instead of a combobox (see this community example).
2.  Load the items from a file to populate the combobox at the beginning.  After editing the combobox, dump the items of the combobox to the file.
Rod T.
