Example Code
Programmatically Display VI on Specified Monitor
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how VI server can be used to set the display monitor and position (i.e. maximized or minimized) of a VI at runtime.
Description
This example uses property nodes to set the display monitor and position (i.e. maximized or minimized) of a VI at runtime.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI.
VI Block Diagram
James K.
