Programmatically Determine if a Sub-VI or VI is Running in LabVIEW
Produtos e Meio Ambiente
Esta seção reflete os produtos e o sistema operacional utilizados para criar o exemplo.
Para baixar o software NI, incluindo os produtos abaixo, visite ni.com/downloads.
    Software
  • LabVIEW
Código e Documentos
Anexo
Baixar tudo
Overview
This VI demonstrates how to programmatically determine if a sub-VI or VI is running on your computer.
Requirement
LabVIEW Full Development System 2012 or compatible
  1. Enter the path of the VI to determine its status
  2. Run the VI, The VI will return the following Execution States:
    Bad—VI has errors and cannot execute or VI is not currently running
    Idle—VI is not running, but is in memory.
    Run top level—VI is the top-level VI in an active hierarchy.
    Running—VI is reserved for execution by one or more active top-level VIs.
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Aaron W.
Ao enviar o código para a Comunidade NI, você concorda com as condições da licença MIT. Saiba mais sobre a Política de licenciamento de exemplo de código da NI.
Comentários
comrade
Active Participant
Active Participant
em
And to determine whether a VI with Exec.State "Running" as actually being run at the time, try this:
https://lavag.org/topic/16660-how-to-get-actual-vi-execution-state/#entry109694
