Example Code
Programmatically Determine Control Data Types
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Programmatically determine control and indicator data types.
Description:
The example demonstrates how to programmatically extract data type information on each control and indicator in front panel
Steps to implement or execute code
To implement this example:
  1. Run the VI
  2. (Optional) Turn on the Highlight Execution to see the flow of the VI
Requirements
Software
LabVIEW 2012 or compatible
Hardware
2017-10-31_20-52-14.jpg2017-10-31_20-52-14.jpg2017-10-31_20-52-24.jpg2017-10-31_20-52-24.jpg
Shalini B
National Instruments UK & Ireland
Comments
josborne
Active Participant
Active Participant
on
This is nice to know its possible!
http://www.medicollector.com
ackatharotiya
Member
Member
on
Hi Shalini,
That's life saver vi. Thank you.
I was wondering if you have another VI related to this one; that creates an array of  respective elements as well. I look forward for your reply.
Thank you
carlos_camargo
Member
Member
on
This is a great example but it uses deprecated VIs, might want to update to use current ones.
I redid using VIs in
C:\Program Files (x86)\National Instruments\LabVIEW 2017\vi.lib\Utility\Data Type
The floating help for the subVI's in the deprecated example point you to that folder.
It's easy enough once you realize that folder exists!  Just have to know to use: "Get Type Information" from that folder/library.
