Introduction:
If you need a way to programmatically detect and list all controls and indicators on a VI front panel, this can be done through the use of property nodes. This example detects all indicators on the front panel, places them in an array, and writes the indicator names on a front panel Array Indicator.
This example is based on this NI Discussion Forum post:
http://forums.ni.com/t5/LabVIEW/distinguishing-between-indicator-and-controls-using-property/td-p/12...
Instructions:
1. Place any control or indicator on the front panel.
2. Run the VI. Notice the array being build in the case structure for indicators. If you would like to also detect controls, you could set up a separate array for the False case (when the front panel item is not an indicator).
Software:
LabVIEW 2011
The link appears to be broken
Thanks for catching that. The thread was moved and I've updated the link.
