Introduction
The LabVIEW Datlogging and Supervisory Control Module makes it possible to programmatically deploy libraries as well as modify shared variables and processes. This example deploys a library, lists the shared variables, and deletes user-selected variables from the Shared Variable Engine as well as the project library on disk.
Steps to Complete
Run prog_delete_var.vi, attached, and follow the steps on the front panel. The default is to use the attached library, to_modify.lvlib, saved to the C:\ directory but it is possible to browse to any library.
Additional Notes
This code can run as a VI or a stand-alone application. If building it into an executable, be sure to check "Enable Enhanced DSC Run-Time support" under the Advanced application properties. Running the executable requires the LabVIEW DSC development software or the LabVIEW DSC Run-Time System.
Jennifer R.
