Example Code
Programmatically Create X Markers on XY Graph Using LabVIEW
Code and Documents
Overview
This VI is designed to programmatically create X markers on an XY Graph.
Description
This VI is designed to programmatically create X markers on an XY Graph. This was originally created to address an issue in LabVIEW 2009 (fixed in LabVIEW 2009 SP1), where XY Graphs do not populate X markers correctly when using absolute time on the X scale.
It uses Graph property nodes to adjust the XScale properties to the increments specified.
Requirements
LabVIEW 2012 (or compatible)
  1. Use this VI as a subVI in your program by wiring the reference (refnum) of the Graph into the 'GraphChart Refnum In'.
  2. Run your program
The only required input is a reference to the graph or chart you would like to add markers to.
Make sure you run this code after you have updated your indicators. If you want the markers to update as you zoom, then your program will need to rerun this specific subVI after a zooming activity occurs.
The screenshot below illustrates how adding X Markers to a Graph would look like.
Comments
FIC
Member
Member
on
So if we migrate to LV 2009, this VI needs to be added..!? Is there a plan to release a Patch sometime soon? Becasue if that happens now we have to remove the VI. If a definite date for patch is communicated, it will be help people make a better decision to migrate now or wait till later. As for us we have reverted back to 8.6. This bug was severe and there were other things such as TDMS file compatibility that got us thinking if it is worth the upgrade.  We feel that a known devil (LV 8.6) is better than an unkown one (LV 9.0). Thanks for your effort though and if a target date for patch is communicated it will help
Not applicable
on
I have added a a more sophisticated version. It calculates the number of Markers for resizeable Frontpanels itself and calculates a better increment value. For example: Better use 5:00 than 4:48.
sletrab
HunterSeeker
Member Member
Member
on
You should be able to go to the edit page an add your version, just be sure to title it something clear.
Not applicable
on
My VIs were deleted (don't know why), but the problem is solved in Patch2 for LabVIEW 2009. Look for for example for "2009 f2". The patch works.
sletrab
