Overview
The example demonstrates how to create a polygon Region of Interest (ROI) programmatically.
Description
The example shows how to programmatically create an image that is not necessarily rectangle-shaped.
By default, images are always rectangle-shaped. To work around this one can create a mask from a Region of Interest (ROI) that is applied onto the image to apply non-rectangle image shapes.
The example provides to possibility to define any ROI type programmatically that is later used to mask the image to the desired shape.
Requirements
Software
Hardware
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text 'NIVerified'. Read here for more information about the new Example Guidelines and Community Platform.**
Amazing program. This program made my job so easy. Thank You Daniel.
Empezando Estoy pana estafa labview cuando abro tu programa la parte de imaq roit o mask esos iconos me aparecen en blanco q debo hacer
Creo que necesitar este: https://www.ni.com/en/support/downloads/drivers/download.vision-acquisition-software.html#306463
yo tengo instalado ni imaq 2012 porqte tengo labview 2012 tu crees q pueda instalar el 2014 para q me aparezcan esos iconos?
