Overview
This script rogrammatically modifies the X-Axis label of a graph from DIAdem and demonstrates how to configure the graph objects and properties.
Description
This example shows how to navigate the graph properties in DIAdem. The specific property to modify in this case is the XAxis label text. DIAdem Help for D2AxisXTxt specifies the type of the main object to be 2D-Axis and the type of the subobject to be 2D-XAxis. After creating the object reference to the 2D-Axis, retrieve the 2D-XAxis subobject. If you do not know the object name, use the object type to find the object name. In this case, D2AxisXObj enumeration can be used to iterate through the existing 2D-XAxis objects starting at index 1..AxisNoMax. This example only has 1 2D-XAxis so specify 1 as the index.
For more information on the 2D Axis objects, see the DIAdem Help files:
DIAdem Help Topic: Accessing Objects in DIAdem REPORT
DIAdem Help Topic: Variable: D2AxisXTxt
DIAdem Help Topic: Variable: D2AxisXObj
- From the SCRIPT tab in DIAdem, open the attached .vbs file.
Requirements
Software
DIAdem (tested in 2012)
Additional Images or Video
The modified graph should look like this:
Code Snippet
Call GraphObjNew("2D-Axis","my2DAxis") 'Creates a new 2D axis system
Call GraphObjOpen(D2AxisXObj(1)) 'Opens reference to X-Axis
D2AxisXTxt = "A Lovely X-Axis"
Call GraphObjClose(D2AxisXObj(1))
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
