Example Code
Programmatically Changing the Colour of an OK Button according to an Input in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
 Overview
This example shows how to programmatically change the colour of the OK button dependant upon which input signal is received
Description
This example shows how to programmatically change the colour of the OK button dependant upon which input signal is receieved. For example, is a value change at Input 1 is received the OK button will blink RED, when there is a value change at input 2, the OK button will blink GREEN and so on.
Requirements
LabVIEW Base Development System 2012 or compatible
Steps to Implement or Execute Code:
  1. Run the VI
  2. Change the Numeric inputs value to blink the OK button depending on color definition in each case
VI Block Diagram
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
