Example Code
Programmatically Change the Text on Another VI's Front Panel
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This program opens a VI and changes the front panel text depending on the selected resolution.
Description
The program allows you to select the path to the VI you want to view and the resolution at which you want to view it. The VI adjusts all font sizes and front panel controls appropriately for the resolution you choose.
Requirements
LabVIEW 2012 (or compatible)
1. Select the VI you would like to make the changes on.
2. Select the desired resolution.
3. Select the Run button.
Chris Van Horn
