This example demonstrates how to change the network settings for the 2 ethernet ports in a Linux RT CompactRIO Controller.
Network settings can be configured for both eth0 and eth1 in Linux RT targets with 2 ethernet ports. This can be done regardless of the connection being used (usb, eth0 or eth1).network settings.png
Configurable settings for each port are:
The target's hostname can also be changed.
Hardware:
-Linux RT CompactRIO Target.
Sofware:
-LabVIEW 2016 or later.
-NI System Configuration 16.0 or later.
1. Open the Change Network Settings Linux RT.lvproj file.
2. Open and run the Main - Change Network Settings.vi.
3. Enter a valid IP address for the cRIO.
4. Click on Connect.
5. A new window will open where you can change the network settings for the 2 ethernet ports in the CompactRIO.
6. Click on Apply and Reboot to change the settings.
This example was made reusing some of the code used in the Replication and Deployment Utility (RAD) to change network settings. This was modified to allow changing settings for the 2 ethernet ports regardless of the connection being used (usb, eth0 or eth1).
