Example Code
Programmatically Change Meter Colors Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
 Overview
Use this VI to programmatically change the color of a meter indicator.
Description
This example demostrates how  to programmatically change the color of a meter. This application bundle couple composed by color box constant togheter and then change meter indicator colors using a Property Node.
Requirements
  • LabVIEW 2012 (or compatible)
1. Looks at meter scale color
2. Run VI
3. Looks that color scale is changed
Top VI Block Diagram
Meter Color Change LV2012 NI verified.pngMeter Color Change LV2012 NI verified.png
A_Ryan
AES
