Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Example Code
Programmatically Change IP Address of Real-Time Target in LabVIEW Project
Products and Environment
    Hardware
  • CompactRIO Controller
    Software
  • LabVIEW
Code and Documents
Description
This example covers a scenario where you have a project with a Real-Time (RT) target, and the target has an IP address that changes periodically, but you need to keep networking as is (cannot set IP to static). The example explains how you can change the IP Address Property of your RT Target programmatically.
How to Use
We can access this property by editing the LabVIEW project's XML file. To change an XML tag, we can use the Set XML Tag method. The tag that we need to call out for IP address is alias.value.
See the attached project for an example of how to use the Set XML Tag method in this manner.
