Overview
This example shows how to change the text color of a string indicator line by line by using property nodes.
Description
This VI changes the color and font size of the active cell. The active cell is selected by the user the same way as choosing an index of a 2D array. In this example, the even iterations will have red and bigger "warnings" and the odd iterations will have blue and smaller "No Warning". This is also confirmed with a boolean, and the iterations will go on for 10 times. This example can be useful when you need to indicate events with certain colors, which will alert the user about the status more visibly.
Requirements
VI Block Diagram
