Please note: this is not the intended use of the system colors feature. This will affect the appearance of all programs running on your computer!
If a problem occurs and the program is not able to set the system colors back to their default values when the VI stops, logging out and logging back in to your Windows account will reset your system colors.
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
