Example Code
Programmatically Calling subVI without using VI Server using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example demostrates how to call a subVI from a top level application without using VI server calls.
Description
This example demostrates one method to call a subVI from a top level application without using VI server calls. Using VI server is normally recommended; however, if you are distributing an executable and do not want to include the VI file in the support folder this example is an acceptable alternative.
This example uses a global variable to communicate the stop condition from top level VI to subVI.
Requirements
  • LabVIEW 2012 (or compatible)
1. Run VI
2. Press Start SubVI button
3. Press Stop SubVI button
Top VI Block Diagram
Call subVI Example using LV2012 NI verified.pngCall subVI Example using LV2012 NI verified.png
Jonah Paul
Marketing Manager, NI Software
