Overview: This VI gives programmatic access to the clipboard.
Description: The system clipboard is a very useful tool when trying to share information between applications, such as string or numeric data. The actions that we take when performing copy and paste operations are also programmatically available in LabVIEW, and can be used to share information between a VI and another application in an automated fashion. The attached example VI demonstrates that through the use of invoke nodes, we have programmatic access to reading and writing to and from the system clipboard.
Requirements: LabVIEW 2012 (or compatible), Hardware: none.
Steps to Implement or Execute Code:
1. Run the VI.
2. Press Write Array to write it to the clipboard (the array will be formatted into string).
3. Press Write String to write the value in the "Write String" text box to the clipboard.
4. Pressing Read to read the clipboard, output text will show up in Read String indicator.
5. Clear Clipboard will write an empty string to the clipboard.
6. You could monitor clipboard state in the What's in the Clipboard control.
Additional Information or References:
Cool, thanks. Simple when you see the code but hard to figure out from scratch.
Thanks for the BRILLIANT TECHNIQUE ![]()
