Example Code
Programatically size window to maximum size during run-time
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI uses property nodes to get the screen resolution of the monitor that you are using and inputs the bounds that it finds as the input bounds for the window run-time position.
Description
It can also be used for multiple monitors by adjusting the unbundle function to shows the bounds from the other monitors and the window will resize appropriately
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI.
  2. The front panel adjust the screen resolution
VI Snippet
David B
National Instruments UK
Comments
Kaydon_Rand_Ste
Member
Member
on
Works well - thanks
cirrusio
Active Participant
Active Participant
on
For whatever reason, this entry shows up first when you search for programatically maximizing the front panel.  Why not use the FP.State property to maximize the window?
Here you can also set the monitor to display this on as well as set the FP front most.
