Overview
This VI takes a screenshot of all active monitors and paste the image from the clipboard into a picture control on the front panel.
Description
The VI programmatically takes a screenshot by accessing the user32.dll and simulating a user processing the Print Screen button. Once a screenshot has been copied to the clipboard the image is retrieved using the Clipboard, GetImage method. This returns an array of points that we convert into a pix map that can be passed into a picture control.
Requirements
VI Block Diagram
Thank you David-A for sharing this helpful code.![]()
With little modification I was able to fit in our requirement.
Just a point to add -
To get the active window screen print, enter 18 (x12) for second argument(i.e. MASK) to lib call.
It's that simple to get ALT-PRINT SCREEN!!![]()
Regards
Yogesh Sinare
Glad you found it useful. And that's a good tip. Thanks for sharing!
It appears that 18 (x12) is not universal for ALT for the second argument.
Hmm - it is universal for ALT - I must be doing something wrong - as it is not working for me to snap only the selected top level window.
