Example Code
Producer/Consumer Architecture with Keyboard Input Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI shows how to use the producer/consumer architecture to queue up keyboard inputs in the producer loop and perform actions based on the input in the consumer loop.
Description
Use this template to build a producer/consumer design pattern with events to produce queue items. Use this design pattern instead of the User Interface Event Handler pattern for user interfaces when you want to execute code asynchronously in response to an event without slowing the user interface responsiveness.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run the VI, press the "F" key will toggle the indicator and wait for 1 second.
  2. If you press the "F" key faster than once per second, the presses are queued up to demonstrate that no input is lost.
VI Snippet
