This VI programmatically makes a copy of the screen and draws it in New Picture indicator
2. Description:
This VI uses a call library function node to Print Screen what the user sees on the desktop at the time of running the VI. This image is then produced on the front panel with a zoom factor of .5.
In this example the keybd_event functions is used:
VOID WINAPI keybd_event(
_In_ BYTE bVk,
_In_ BYTE bScan,
_In_ DWORD dwFlags,
_In_ ULONG_PTR dwExtraInfo
- bVk is a code that must be a value in the range 1 to 254. (42 is the value for PRINT SCREEN)
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
VI Block Diagram
Actually this VI is not working when we convert it to an Exe File. I donot no why this happens can u suggest ?
