Overview
This VI takes a string and pushes it to the printer using the report generation toolkit.
Description
You can use this simple SubVI whenever you wish to print a report or label. This VI will use the default printer for the computer, including networked printers. You can also specify a specific printer name on the print report vi.
Requirements
Main VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange."
