Overview
This example demonstrates the implementation of principal component analysis using a mixed approach between MathScript and LabVIEW.
Description
Principal component analysis is an algorithm that decomposes a signal into its N components (depending on the dimension) of the signal. This example creates a 3D surface in LabVIEW. The example then plots this data using only one to three of the components.
Requirements
Software:
1. Run VI.
2. Specify the inputs and components.
3. Observe the 3D graph.
Additional Information or Resources
**This document has been updated to meet the current required format for the NI Code Exchange
can i ask a version of your software that will support labview 7.0 ? thanks in advance ![]()
