Example Code
Prevent Grayed-Out Tabs when Programmatically Hiding and Showing Tabs in a Tab Control Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI shows how to make a single tab control page visible and hide all other pages without the pages appearing grayed.
Description
When using the "Pages" property node to make the current tab invisible and show another tab, the current tab will be grayed-out until the user selects another tab, at which point it will disappear. This VI implements an event structure and a for loop to set the visibility property so that the newly visible tab is shown and the tab made invisible disappears immediately without being grayed-out or requiring user interaction.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Click the buttons on the front panel to make that tab control page visible and hide all other pages.
  2. Notice the behavior of the two tab controls. The first method will leave the current tab grayed-out until the user selects the newly-visible tab, while the second prevents that.
VI Snippet
Caleb Harris
National Instruments | http://www.ni.com/support
