Example Code
Pre-Trigger Functional Global Variable (Round Robin) Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI accepts the size of the input array as a single buffer placement, multiply this by the number of elements you want to store.
Description
The VI will over write the element in a round robin approach, providing you with the current location information of the buffer for you to get back x number of data points from the buffer, very useful if you're needing to store samples before a trigger condition is met.
Requirements
  • LabVIEW 2012 (or compatible)
  • Run the program
VI Snippet
