Example Code
Populate Combo Box from INI File
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This example demonstrates how to use an INI file to fill in values for a Combo Box.
Description
The Config File VIs palette offers an encapsulated way to read and write to standard INI files. First we will generate a config file to use with these functions. This VI is an example of how this can be done. First it opens up the config file, converts the string array to a single string, writes the data to a specified key, and closes the file.
If you open up the INI file in notepad you see this information.
Now that we have a config file we will use it to populate the values of a Combo Box programmatically. To do this we open the config file, read the data at the correct location, parse the string into an array, write the array to the Strings[] property of the Combo Box, and set the value of the combo box to the first item in the array.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attached ZIP file (or both of the VIs).
  2. Open and run the "Create Config File.vi" (change values if you want)
  3. Observe how the INI file was created in the folder that the VI executed from.
  4. Open and run the "Populate Combo Box.vi"
  5. Observe how the Combo Box is filled with the information from the INI file.
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Comments
Hecuba
Member
Member
on
I believe that a better and more robust approach to work with INI file is with the use of the functions in the "Configuration Files VIs" subpalette
Mfg. Test Engineer
Certified LabVIEW Associate Developer
