 migration-bot
		01-09-2024
		04:42 PM
      migration-bot
		01-09-2024
		04:42 PM
1. Overview
This example creates, analyzes and modifies a State-Space MIMO model using the Control Design and Simulation Module in LabVIEW.
2. Description
In control engineering, a state-space representation is a mathematical model of a physical system as a set of input, output and state variables related by first-order differential equations. "State space" refers to the Euclidean space in which the variables on the axes are the state variables. The state of the system can be represented as a vector within that space.
The CD Pole Placement VI Determines the Gain that places the closed-loop poles at desired locations in a system with full state feedback. You can use this VI with multiple-input multiple-output (MIMO) systems.
3. Requirements
4. Steps to Implement or Execute Code
5. Additional Information or References
**The code for this example has been edited to meet the new Community Example Style Guidelines.**
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
