Example Code
Plotting Single Points Using XY-Graph Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code shows how to plot single points using an XY-Graph and then uses property nodes to set the graph settings for best visibility.
Description
This code accepts two user-input arrays of X and Y points. It then bundles them into a cluster of 2, 1D arrays to be plot on the XY Graph. The user than has the ability to change the property nodes for interpolation and point style. The default properties of this graph do not display this data as points but as an interpolated line.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the VI
  2. Run the VI
  3. Input values into the X-Array and Y-Array
  4. Observe points being plotted on the XY Graph
VI Block Diagram
