Example Code
Plotting Multiple Y Scales on an XY Graph in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
This VI plots two signals and shows how to enable a new Y-Scale for the second chart using an XY Graph Property Node.
In order to enable a scale on the block diagram, you must first create it on the front panel.
To do this, right-click on the Y-Scale that is enabled by default on an XY Graph, and click Duplicate Scale.
This scale can then be seen in the Scale properties and can be enabled on the block diagram.
Related Links:
NI Products and Services: LabVIEW
