Overview
This VI calls a MathScript Node to generate a list of 100 random numbers between 1 and 10 and plot.
Description
This VI calls a MathScript Node to generate a list of 100 random numbers between 1 and 10. We then change the plot attributes to make the plot green and have a -. pattern. The plot is also designed to open up in a new window when run.
Requirements
- LabVIEW 2013 (or compatible).
- LabVIEW MathScript RT Module.
1. Run the VI.
2. The plot attributes are green color and have a -. pattern. The plot is also designed to open up in a new window when run.
Joel I.
